Resolved Resistance values for 1G Fuel sending unit
98awdturbo
61
Dec 9, 2010
Waterford, Michigan
Does anyone know the resistance values for 1/4, 1/2, 3/4 and full for a 1G sending unit? Thanks!
Solution
Unfortunately, the FSM doesn't give standard resistance values for all those positions; it states that at point F (full) you should read 3 +/- 2 ohms and at point E (empty) you should read 110 +/- 7 ohms. It does state that the resistance should change smoothly when the float moves slowly between F and E.
Maybe that will help you out.
Solution
