Differences in 7-bolt cranks?
90-GST
106
Aug 15, 2008
St. Louis, Missouri
What are the differences in a 7 bolt crank between the 95-97 engines, and the 98+ split thrust bearing engines?
I have two blocks, one is an Evo3 block, and one is a 98 block. I'm rebuilding the motor, and both need a new crank. I'd prefer to use the 98 block, and found a crank from a 96 block. I basically wanted to know if there were differences in the two cranks or if they used the same design?
