11secDSM
- 749
- 9
- Sep 8, 2003
Collegeville,
Pennsylvania
I just got my trans back today and noticed the car will not roll backwards, in neutral, with the car not running. While the trans was out awaiting a new converter, I pulled the trans pump to have it checked (everything checked out), and I also pulled the valve body to make sure the pressure adjustments were turned all the way up.
I went ahead and pulled the trans pan to check if the selector was lined up with the valve body and it was. I also pulled the valve body off and it still will not allow the wheels to roll backwards.
Before I go and pull the trans back off, would something in the pump or front clutch basket prevent the car from rolling backwards?
...I appreciate you trying to help, but let's move on from the brakes. I know how to diag issues, just not 100% sure of the cause in this case.
I've never tore an auto apart so I can't even guess what could be causing that problem, I'm sure there are some auto wizards on here that might be able to help you out. Sorry I tried
