DJ Raydiate
- 610
- 15
- May 27, 2010
Jacksonville,
Florida
I figured I would go ahead and start a thread on my LED upgrades. I am planing to do custom LED tail lights that are inspired by the Dodge "Race track Light" and will look something like this:
Everything is going to be controlled by a central control bard that will be connected to the car via 1157 bulb base adapters and a 3 pin plug. This way the only places that I would have to tap into the car is the 3rd brake light signal and the tag light + and -. The control harness will consist of 2 1157 base adapters and a 3 pin plug going into the harness, and then a 7 pin plug and 2 20 pin ATX plugs going into the control box. I will have a 20pin ATX plug going into each of the tail lights and a 7 pin plug going into the center.
Here is the schematic that I have drawn up for the control board.
When it is all said in done, I will have sequential turn signals and a very unique rear for an Eclipse.
It will be starting the conversion very soon so I'll keep that updated.
I have went ahead and started on other things however. Today I made the harnesses for the Demon eyes for my car and did a test fit.
I still have to take the headlight out and get the LED mounted into the projector. I do plan on doing a true HID retrofit to the headlights so the mounting would be somewhat temporary.
All of this would be just the start of things to come on my LED upgrade Path. I will not be using any of the pnp LEDs that they have out there. Everything will be hand soldered and custom fit to the car so its going to be fun, fun.
.. doesn't talk about dimming.
so I looked into REFLECTIVE CONSPICUITY TAPE (the kind that you see on the side of trailers). I just wasn't sure if it was conductive or not. I had a suppler send me some samples for me to test out.
. My father-in-law had some dollhouse electrical tape laying around so I took some
