4G Slap Shift Downshift Broken
Luckris
Mar 27, 2015
Detroit, Michigan
My entire PC freezes when I try to go to any club4G websites so I figured since I still track my 2G I could get a little help here.
Basically I bought a 07 Eclipse Spyder GT slap shift auto. And you can use slapshift to go up, but the minus will do nothing. I'm clueless since I'm used to my manual talon :p
Try this link to diagnose the Sportronic shifting issue.
Starting page (23A-331):
http://tearstone.com/eclipsefsm/2006_PS24S_MMNA_SM_PDF/GR00004100-23A.pdf
From 4g page:
CIRCUIT OPERATION
If the select switch of the shift switch assembly is set to the sport mode, battery positive voltage will be applied to the PCM (terminal 39). If the shift switch of the shift switch assembly is set to "UP" or "DOWN" position, battery positive voltage will be applied to the PCM (terminal 32, 36).
COMMENT
When sport mode shift does not operate the cause is probably a malfunction of the transmission range switch circuit, shift switch assembly circuit or a defective PCM.
TROUBLESHOOTING HINTS (THE MOST LIKELY CAUSES FOR THIS CASE
•Malfunction of the transmission r
ange switch
•Malfunction of the shift switch assembly select switch
•Malfunction of the shift switch assembly shift switch (Up)
•Malfunction of the shift switch assembly shift switch (Down)
•Damaged harness or connector
•Malfunction of the PCM​
