- 11,533
- 29
- Apr 8, 2002
Chandler,
Arizona
I'm having the issue descibed here.
taken from RRE's page
I've never adjusted the "upper pedal stop adjuster" My question is do you loosen it or tighten it? I can't tell from the pics and I searched and didn't get a thread that told you specifically how to adjust it.
TIA.
2G Pedal "Pump Up"
If you are fighting an inconsistent pedal adjustment in a 2G, adjust the upper pedal stop adjuster so that you gain additional free play at the top of the pedal travel. If this is your problem, you will notice that the pedal suddenly gets very tight and the release point will suddenly move up a lot, this is the cause.
TIA.
