2G 2g AWD fuel pump install
I was just randomly looking through here to see if there are any how to installs for a fuel pump. I have a customers 99 GSX in the shop today and we are diagnosing a fuel pressure issue but the whole process is the same.
Always when messing with fuel disconnect the battery.
I used a 19mm wrench, 14mm line wrench, phillips head screw driver, large flat headed screw driver, hammer, and vise grips.
I don't know of a way to drain the gas that is stuck in the fuel lines so I just let the fuel pressure drop(let the car sit for a while or if you have an AFPR wait till it shows 0 psi)
The car-
First off get under the car and use the 14mm line wrench and the 19mm wrench to loosen this connection which is on the passenger side of the car in front of the gas tank
Then remove the back seat. There are two little tabs that you pull out under the front of the seats that will release the seat. When you get the seat out on the passenger side of the car there is an access panel. 4 phillips head screws hold it in and might as well take the 1 screw out that holds the harness to the car to make the whole piece move easier
There are two connector that you have to unplug when you pull the access panel back. 3 hoses connect to this fuel sender. 2 are held on by clamps and one is an inverted flare fitting. That inverted flare is the PITA. This car was worked on before so I used vise grips were the 14mm would normally go.
Be sure not to twist that metal line up to much. It is brittle and can break.
Once you get the lines out of the way take a large flat headed screw driver and a hammer and spin the outside ring counter clockwise to loosen it
Once that is loose you can just pull the fuel pump out. Be careful to not hurt the fuel level arm on removal and installation.
The problem with this fuel pump can be seen in these pictures. There must be a spacer that pushed up on the o-ring to ensure that the pressure from the pump does not push down on the o-ring and blow it out like this one did.
Remove this screw to allow the pump to be released from the sending unit.
I had an EVO 10 stock fuel pump laying around and it had the spacer required to install this pump correctly. It goes spacer, oring, and then the little brown cap.
This was not working
This will work
From here just reverse the whole process. Make sure to install the fuel feed line to the sending unit before you install it underneath. I hope this helps out the tuners community. Thanks guys
The car-
This will work
Thank you for the write up!
My fuel pump top hat doesn't have the white locking ring. It's an early 95 2ga talon and I have a bunch of little nuts around it. I don't see a how to for that style around here :/
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
