FIBA M - EC17PSE
Supporting Vendor
- 6,753
- 5,159
- Nov 1, 2008
Orlando,
Florida
Hello Tuners and welcome to my first item of suspension I have developed!
This is the first part of my suspension items im rolling out with other items to follow some time soon.
Central hole in bracket will now be removed leaving just the outer and inner hole as pictured in the last picture.
These are Rear upper wishbones with adjustable roll center adjustment brackets.
Made from CDS (seamless) steel tube all Tig welded with very strong Chromoly rod ends (kevlar injected) with rubber dust covers and laser cut brackets and all hardware is 12.9 grade socket capped bolts and flanged nylocs!
They will be cleaned then zinc primed and powder coated a matte black finish!
These weigh in at 4.3 LBS for the complete kit/side, moving parts weigh in at only 2.7 LBS!
Oem with SPC or ingalls adjusters weigh in at 5.4 LBS and moving parts are 4.1 LBS and the Galant is a little lighter then Oem.
The arms offer -2.2 degrees of camber and also +1.5 camber. Each hole on the outer bracket is spaced equally to offer precise adjustment for both sides.
The Inner bracket is a little different then anything else for our cars as I have made it to incorporate inner pickup adjustments which allow you to adjust roll centers and find that good setting for getting the best out of your setup and ride height of your car, This was done to counteract the bad effect lowering your car has to the suspension system and controlling arm movement is critical for mechanical grip
I have been running mine with great results! it is a little noisier as to be expected as its now not using any rubber on them and its alot stronger too.
Effects of Rear Roll Center Adjustment (each car is different and will respond differently)
Rear roll center affects on- and off-throttle situations in all cornering stages (entry, mid, exit)
LOWER roll center
+ More on-throttle grip
+ Less grip under braking
+ Use to avoid traction rolling at corner entry (increases rear grip)
+ Use under low traction conditions
+ Increases traction, reduces rear tire wear
HIGHER roll center
+ Less on-throttle steering
+ Car is more responsive
+ Use in high grip conditions to avoid traction rolling
+ Use on tracks with quick direction changes (chicanes)
Please read details
Price is $370 Shipped via Fedex, Fully tracked and insured and all items ship from the UK.
I will end this in mid JAN 2017 and I hope to have everything in and done ready to ship end of Feb 2017, I will keep the group notified here or PM's of course through out the build.
PAYMENT
I will start off with a half deposit to secure and when the list has filled up and closed I will ask for the rest before I start to do the final ordering! I wont be doing swap with deposits from 1 person to another as it creates issues I would rather avoid.
Please ask any questions or anything at all and I thank you for reading.
Lets help me get some very useful adjustable arms out on the market for our cars, This will help me progress with the other suspension items I plan to bring out and sell aswell and the more folks that buy these the more it can proceed to go ahead and become another item on the market for us,
List of people buying suspension arms.
1. mountain_man (paid) SHIPPED!!!!!
2. iLeagleracing (paid) SHIPPED!!!!!
3. Apache (paid) SHIPPED!!!!!
4. TheLemon (paid) SHIPPED!!!!!
5. llxkevinxll (paid) SHIPPED!!!!!
6. mitsumikey (paid) SHIPPED!!!!!
7. Dsmcrzy (paid) SHIPPED!!!!!
8. 95eclipser (paid) SHIPPED!!!!!
9. jls_frog (paid) SHIPPED!!!!!
10. T2Small (paid) SHIPPED!!!!!
11 Ceedawg (paid) SHIPPED!!!!!
12 Rival (paid) SHIPPED!!!!!
13 Phudu2004 (paid) SHIPPED!!!!!
14 TSIAWD666 (paid) SHIPPED!!!!!
15 Eclipse 1998 (paid) SHIPPED!!!!!
16 Xska555 (paid) SHIPPED!!!!!
17 96dsmftw (paid) SHIPPED!!!!!
18 Asexton6969 (paid) SHIPPED!!!!!
19 Slowwhite (paid) SHIPPED!!!!!
ALL SHIPPED!!!!!!!!!!!
LOWER roll center
HIGHER roll center
Please read details
PAYMENT
