Formula Races (Extreme Class).
9d2TSi
1,215
Jun 5, 2003
Battle Creek, Michigan
Hey all. My question is. What did you guys do to your Formula cars to beat the others in this series of races? I've tried different trans/suspension settings and still can't beat the other cars. Any help would be sweet.
Later.
depends on if you are playing A spec or B spec, if its A spec, then drive better. for B spec i figured they are f1 cars, they can atleast take most if not all turns at really high speeds so i set them to either 5-push or 4-fast almost the entire time. your car will slowly pass the others and in time lap them, thats how i won it. (the races take so freakin long it isnt funny. it took me 2 weeks to get it over with because it was so boring) there are a couple courses that are mostly straight and so i worked on tuning the gears before the f1 races for top speed and everything worked out great switching from set a for normal races and set b for high speed races. hope that helps you out some
has anyone been able to up-grade your tires for these races? or even for your f1 cars. i'm almost done, (2races left) just woundering if i some how i missed how to buy tires for it.
I used a f1 car and i did part a spec part b spec. I usually start the race in a spec and when i build a decent lead, i switch to b spec. Some races like cote d'azur which have no grass, you can leave the b spec guy on 5 and he wont go off course .
Good luck
