6 bolt swap turbo coolant lines
KeelesKustome
882
17
Dec 29, 2007
Waverly, Tennessee
is this how the lines should be on the 1g swap? i plugged 1 line off and added a niple on the waterneck
alright here is what i did tonight...... please tell me it is right.
i tried to weld this where it looked like it was on the 2g, at the same angle
my remedy to block off the last line
gosh i hope my problems will help others out in the future.
my baby
does this look like the coolant lines are setup correctly now? anyone?
no check my other thread, i have a forward facing oil filter with no lines.
is this how they should be run?
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
