Quote:
Originally Posted by dsmdeliveryboy
I was under the impression those don't fit, but I could be wrong. And just wait it out and buy a Evo 3 housing so you won't have to be spending another $75 down the road when the ebay one cracks. I'm not saying a used Evo housing won't crack, but I think it will last longer. GL man.
- They fit absolutely fine. You may have to shim your wastegate actuator a bit, and you'll definitely have to enlarge the hole in the end of your MHI actuator, but a knockoff housing will fit and function perfectly.
- I've recently rebuilt an eBay 20G that had over 30k of use on it, and the turbine housing did not have a single crack. I've also held MHI turbos that had as little as 5k on them in my hands which were starting to crack around the wastegate hole. Neither housing is crack-proof, but I wouldn't go as far as saying the MHI housing will last longer.
