where to get exhaust housing?
90rslaser
266
Apr 1, 2008
cheyenne, Wyoming
alright guys. so i just picked up a t4 turbonetics turbo. i believe it was a 60 trim. and it had a 38mm wastegate flange on the exhaust side. so the problem is, that the flange on the turbo is way bigger than a normal dsm t4 flange. so where would i get a new exhuast housing to bolt up to this turbo?
What hotside is on it now? Most 60 trims are mated to a T3 turbine housing. Is your T4 divided? Undivided? What's the A/R of the housing? There is no such thing as a "normal" T4 DSM flange. Are you looking for a housing that bolts directly to the stock manifold? Do you have an aftermarket exhaust manifold? T3 manifold? T4 manifold? We need more details.
ive got the hafe exhaust t4 manifold. that a 14b, 16g, 20g will bolt up to. i have never seen anyother style t4 manifold on a dsm. they are always the same size. it is a 60 trim i believe. and if i remember correct, the exhaust side says .58ar on it. i need to get an exhaust housing for the turbo that will bolt up to my hafe manifold. so where can i find one?
NO such thing. T4 housing will only bolt up to a T4 flanged manifold. NO Mitsubishi turbo will bolt up to a T4 manifold. Bolt patterns are different. T4 opening is rectangular, DSM is round.
DSM manifold
T4 manifold
I believe Bullseye makes one, but not sure if it will mate up to a T3/T4 CHRA. If you want to get rid of that housing cheap, let me know. I'm looking for one like that.
