Forced performance would know for sure but, most 4g63's run between 15-50 psi at the cylinder head through the rpm range, and the 20g survives in that range. I doubt the turbo failure's are oil pressure related, the kit's seem poorly engineered with not a lot of thought put into them. Are the turbo's actual mitsubishi turbo's or are they chinese knock offs?
If you haven't already purchased the aps kit, I would go another route. Something with larger ball bearing turbo's, or a big single with a huge T4 hotside. Twin 20g's just seems like a disaster waiting to happen, with all of the backpressure from the small T3 housings and the horrible O2 housings supplied with the kit.
____________________________
-Luke
