Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Turbo System Tech
Turbo System Tech Turbos, Intercooling, Boost Control, Wastegates, etc.
Reply
LinkBack Thread Tools
Old 09-18-2008, 05:12 PM   #1 (permalink)
Proven Member
asd_gst's Avatar
Region: Southeast
Classifieds Rating: (6)
Reputation: asd_gst is more helpful than not
anyway to fixed a cracked exhaust housing on 14b?
is there anyway to fix a crack in the housing or anywhere to buy a new housing for a 14b the hot side?
Offline
Related Auctions
Sponsored Links
Old 09-18-2008, 05:16 PM   #2 (permalink)
Proven Member
bastarddsm's Avatar
Timeslip: 16.070 @ 88.000
Region: Midwest
Classifieds Rating: (1)
Reputation: bastarddsm is more helpful than not
You can try to get some nickle rod and stick weld the crack...
____________________________
Kurt - E85, 450's, China GT, AWD conversion
Offline
[posts] Reply With Quote
Old 09-18-2008, 05:23 PM   #3 (permalink)
Proven Member
Region: Pacific Northwest
Classifieds Rating: (0)
Reputation: tkelly27 is more helpful than not
Just find a used 14b. Or take it to a welding shop. Where is the crack? Is it all the way through? If it's where the turbine sits you will probably want another housing, if it's just cosmetic, deal with it! : )
Tom - '90 Talon on blocks!
Online
Old 09-18-2008, 05:36 PM   #4 (permalink)
Proven Member
asd_gst's Avatar
Region: Southeast
its on the inside where the flapper for the wastegate sits, so the air will get through even when the wastegate is closed
and you cant weld cast im pretty sure if you do it will just crack in a month or week
Offline
Old 09-18-2008, 07:39 PM   #5 (permalink)
Proven Member
HIGHPSI4's Avatar
Region: Southeast
Reputation: HIGHPSI4 is pretty helpful and trustworthy
How big is the crack? If it is small, port out the wastegate hole to minimize the exhaust gases passing it. If it is small, it will tend to seal up as it gets hot. If it is really deep buy another.
Offline
Old 09-18-2008, 07:55 PM   #6 (permalink)
Proven Member
asd_gst's Avatar
Region: Southeast
ok i found another but will a evo3 turbine housing fit a 14b?
Offline
Old 09-18-2008, 07:58 PM   #7 (permalink)
Proven Member
fwdmaster's Avatar
Region: SoCal
Classifieds Rating: (5)
Reputation: fwdmaster is more helpful than not
Quote:
Yes,the evo3 hotside will fit the 14b,I have one on mine
Online
Old 09-18-2008, 08:05 PM   #8 (permalink)
Proven Member
asd_gst's Avatar
Region: Southeast
Quote:
how much bigger is it? do you notice a differnce in spool? not like i care im just wondering
Offline
Old 09-18-2008, 09:05 PM   #9 (permalink)
Proven Member
It's really easy to weld cast iron, people do it all the time. The big issue is letting the piece cool slowly, the cracks come from going from the welding temperature to the cooler temp too fast. It's the 7cm vs. the 6cm housing if I remember correctly, you could probably search for 7cm 14b and find something.
Online
Old 09-18-2008, 09:10 PM   #10 (permalink)
Proven Member
asd_gst's Avatar
Region: Southeast
how do you control how fast it cools?
Offline
Old 09-18-2008, 10:08 PM   #11 (permalink)
Proven Member
big_d's Avatar
Region: Tri State
Reputation: big_d is an unknown
My brother did this to his 14b hotside. We ended up gasket porting it to a 7cm. He hits full spool in the mid 2k range. It all depends on how badly the housing is cracked.
Offline
Old 09-18-2008, 10:40 PM   #12 (permalink)
Proven Member
turboglenn's Avatar
Region: Midwest
Classifieds Rating: (2)
Reputation: turboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthy
In your oven or with an oxycetaline torch using either a laser temp guage or temperature marker/crayons so you know where you're at on heat. Bring it to about 450-550* F and then only weld about a 1/2 to an inch at a time and then put it back in the oven untill the temperatures equall out and then start welding again. It's not so much the speed at which it cools, but the forces of the expanding and contracting of 2 areas of the part that are too far off from each other on temperature.. It's basically the hot metal fighting the cool metal.
Due to the nature of cast iron, no matter how good of a welder some one is every time you weld cast exhaust manifolds it's a roll of the dice on if it holds. The thousands of heat cycles they go through combined with all the carbon deposits from burnt fuels passing through it contaminate the metal to where sometimes it just can't be fixed or at least won't hold. ANd that's on top of the fact that there are so many different alloys used in cast iron parts that it will start to feel like it requires a different technique and machine settings in order to get a good weld every time you do a different part.
I would say about 80% of the time with proper prep they can be fixed. And the nickel rod that is used to weld cast can be smoothed with a porting bit or carbide bur and will clean up really nicely and make it fit perfectly again.
Offline
Old 09-19-2008, 08:54 AM   #13 (permalink)
Proven Member
fwdmaster's Avatar
Region: SoCal
The stock 6cm exhaust outlet is 2" while the evo3 housing is 7cm and has a 2.5" exhaust outlet,for me spool was better as well as midrange/topend
Online
Old 09-19-2008, 10:58 AM   #14 (permalink)
Proven Member
asd_gst's Avatar
Region: Southeast
alright cool, my friend is sending me a evo3 housing
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cracked Exhaust Housing pecka Newbie Forum 17 02-08-2006 08:31 PM
TD04-13G Exhaust Housing vs. TD05-14b Exhaust Housing myshtern Turbo System Tech 1 07-26-2005 04:13 PM
cracked exhaust housing slozee Newbie Forum 5 08-13-2004 01:59 AM
Cracked Exhaust Housings? 14b DSMKevan Newbie Forum 4 07-14-2004 11:31 AM
Cracked wastegate/exhaust housing??? evotuner Newbie Forum 1 10-22-2003 06:01 PM
Page generated in 0.19558811 seconds (81.57% PHP - 18.43% MySQL) with 10 queries
