The_EE
- 838
- 5
- Feb 25, 2006
Clinton,
Missouri
Ok, I had three areas I could put this in, didnt know which one for sure so I picked this one as its what the problem is for.
Running in to a couple issues and wondering what you think can be done about this.
Situation is, I am currently trying to figure out how the hell I am going to plumb all the piping for the new turbo. The 2g water pipe had fittings capable of working with this setup no problem, the 1g seems to have some issues.
1g water pipe has a J shaped fitting that comes off the bottom.
2g block has a water fitting that comes off the block.
If I use both fittings, the one off the 1g pipe and the one off the block, there is no way to bolt the water pipe up to the block as seen in this picture.
So, I really only have one choice, which is block off the passage, like I did since my 20g is only oil cooled and run the water feed line to the turbo from the bottom of the water pipe. This leaves me with a problem. Where to return the water to the system?
Now, since I am running a 1g water neck, I have an extra bung available to use to return piping to the system, I am wondering which way I can go.
Two situations are.
Leave my coolant temp sensor where it is or move it to the higher location.
Nice new looking connector is my coolant temp sensor at the bottom, at the top is some sensor, dont know what but that is how I got the pipe. I am assuming it was a coolant sensor for the 1g. So I was thinking, running the other water line from the back side of the turbo to one of these using a brass barbed fitting, solving my problem.
So, can someone give me an idea if this will work out?
Problem is, what size is the fitting? I picked up a 3/8th barbed fitting and its not really wanting to go in all that easy and I am not all about forcing it in there if I dont have to. I did have a spare 3/8th compressor fitting with a flare end which goes in just fine but its a little loose.
Turbo should be here early next week and I kinda need to figure this out but with the 100* temps and 90% humidity, being outside in the sun is unbearable to say the least heh.
Two situations are.
