1fastlaser
- 965
- Jan 25, 2003
glendora,
New Jersey
Well my setups in my profile. Im on a fully built g4cs, ported head, fp2 cams and manley valve springs. Still old school vpc/afc2/eprom stage 3 chip and 880cc injectors. Walbro 255hp. Im pretty tuned right now 25psi on pump 0 knock running 11.2-11.5 on the wideband. Im looking to make more power. Right now the turbo is a to4e 60-1 with a t4 p trim turbine wheel bolt on with the bullseye housing. I figure maybe going to a t67 or something of that caliber, but know that i could probably go to a t3 or t4 turbine housing with a nicely sized a/r would net me bigger numbers and un choke that turbine wheel. I was just seeing if anyone had any insite, im considering a .84 a/r t4 turbine, i know ill be spooling around 4800 or so on which i dont care about. Also mayber putting a s cover on it. I want mid low 10s out of this sucker. Aem is also in the want/need list
