57 Trim in a TO4E housing ( some one had asked)
turboglenn
6,375
123
Nov 5, 2007
RIpley, West Virginia
I searched but coulddn't find the thread where i offered to scan in the map for a 57 trim wheel in an o4e housing. Today i got around to doing it. Here's 4 maps in o4e housings.. you have 50, 54, 57 and 60 trims. The 57 had alot of lines drawn through it by me when i was calculating some things, but i tried to quickly erase tehm in photoshop.
HOep this helps some people.
here's the maps. You might have to save it and use photoshop or soehting to zoom in anough to read the fine print if your internet explorer doesn't have teh zoom function on the lower right corner.
I have the info on lmost all the tubronetics/garret housings, wheels, turbines and many many more maps.. I'll upload any requests you might have ( maps range from all the basic t3's - to4B's and to4E's. I even have the t series maps as well along with all wheel specs for hot adn cold sides
Well, there was a post where a mod or admin said that "we don't have a map for a 57 trim wheel in an o4e housing", i said i could scan one in and they said "please do" so i did.
EDIt: can't find that map, but i do have a flow rating of 55lbs per minute at 76% efficiency marked in my "special notes" section of my turbo charger log and notes binder
