gt-13 coolant question
jonk00000
134
Nov 24, 2004
stormville, New York
i went with sbr's bb gt-13 the turbo has a feed and return spot for oil and water.
they sent me everything i need to feed and return oil but nothin for water.
do i cap off on the turbo where the water should run threw?? or do i have to go n find lines that will work ? stock lines deff won't work
thanks jon
you will need to get some water to that CHRA!
Im doing a GT3076 which is very similar to your turbo. and im going to try this setup.
If it works ill put it in the tech section.
basicly its the stock 1G outlet (looks like it could work) and then Ill use a 2G water fitting of the block, trim off the centering tab and bolt it in like this:
PS, Im using SBR exhaust manifold for water pipe clearance!
