Advice on spring break project
BlackbirdOfPrey
435
Dec 4, 2003
Shiloh,
Just need a bit of advice with my spring break project. The idea is to get a FMIC, new BOV, 3" GM MAS and MAFT in blow through, installed (with 10 days that shouldn't be a problem).
The FMIC is going to probably be Extreme Intercoolers' Race core
http://www.extremeintercoolers.com/new_page_3.htm.
The main question revolves around which BOV to get. The target turbo for this whole mess is something in the range of a 60 trim/60-1, most likely an FP3065. Now I was going to go with a Tial BOV, but the more I look at it, the Forge looks just as good and is about 50 bucks cheaper. The reason this is an issue is that I've read the Forge can only hold up to 30psi(checked the spring strengths), and yet the 3065 can efficiently boost up to 35ish psi,making the Forge inadequate. Then again the Forge uses the same flange as my 1g and I wouldn't need to buy it right away (gonna use the 14b untill I get the 3065, which is the last thing in my upgrade path). Any thoughts would be helpful.
Right from SBR's website. "The biggest blow off valve in the industry! Utiliizing a 50mm valve, you will not find a better blow off anywhere!". That is for the tial.
