just_passed_you
- 183
- 1
- Oct 11, 2004
Anchorage,
Alaska
1G AWD TSI
So...
Finally did some test fitting after a long hard day. (easy to mechanics tough for newbies)
Exhaust manifold studs, double nut the little *&^% !ers and they come out.
Replace with Stainless Steel ones. Easy.
EVO manifold goes on, replacing the 1g stocker. Right hand edge by motor mount
needs to be ground off a little bit so it clears the bracket like so:
(also remove or lower Power Steering Pump, I got rid of mine )
Turbo bolts to manifold, test fit....
No denting the water pipe! They weren't kidding!!!!!
Was worried about the oil drain line after that... threads of the lines being
too short was disturbing, so I checked it out..
Indeed it FITS! it's... very bent, near kinked.. shouldn't be a problem ( I hope WTF )
(could someone confirm whether or not this is the "new" drain kit or the old one?)
And finally, the reason for "clocking" the turbo (I hope I said that right)
Uhh.. yeah.. just a LITTLE too close.
I wish I didn't have to mess with that part, I don't want any extra chance
of screwing something up!
Ok.. I did read some install threads and I'd like to know about 2 things that were confusing...
1.) what EXACTLY to use to plug the coolant line. I took the specs that were used in another install thread... asked the guys at Shucks, I even said "NPT" out loud.
They looked at me like WTF right.. so... anyway, ideas? Thoughts?
2.) The oil feed line.. someone said grab it from a hole by the oil filter to get
filtered oil, per David at Bullseye? I'm pretty sure I need to hook it up to the head?
Someone clarify with a picture or something as I'm totally confused by that. Again..
it doesn't take much to confuse someone like me.
With that said.. if I can install something like this with the help from VFAQ,
and these boards.. YOU CAN TOO. Just.. try not to blow it up when you're done
unless you got the super waranty.
So...
I used a 3/4" plug from home depot.
