mostlygobitshow
- Oct 27, 2004
Ft. Collins,
Colorado
So I blew my small 16g, then a 14b, another 14b, and then today another 14b. On two of them the actual shaft snapped in half and the exauhst wheel came completly free! On the others I drove them for about 30 miles while they ran great and then they started hitting the wall and wouldn't spool, but sometimes would very rarely if they could break free. I'm pretty positive it's not an oil issue because I've tried it with the stock oil feed line and now I have RRE's supply and feed lines hooked up. What the heck is wrong. Right before they go, I get a loud whistling sound when I hit 0 boost and it just holds. I have a 2g mass, 550's, intercooler piping, 3" turbo back, ported 2g manifold, 7 cm exhaust housing, 255 fuel pump, etc... Any help you guys could give me would be awesome. Let me know if you have any questions concerning my problem or set-up and I'll answer quickly. I want my dsm to run like it should....Also, compression is 125 straight across here in colorado and I also performed a leak-down test and found nothing. PLEASE HELP! Thanks guys!
