Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Turbo System Tech
Turbo System Tech Turbos, Intercooling, Boost Control, Wastegates, etc.
Reply
LinkBack Thread Tools
Old 03-22-2005, 05:10 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: gsxonjackstands is an unknown
20 g exh housing on 14b?
ok heres my question i have a 20 g with bad bearings i was wondering if i took the 14b
compressor wheel cold side and swapped it with the on on my 20 g and using the center section from the 14b alsoe i would be swapping the 20g exh housing ### my 14b exh housing is cracked between watse gate passage and the door flapper is not even sealing
is this feasible?
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 03-22-2005, 09:26 PM   #2 (permalink)
Proven Member
Classifieds Rating: (10)
Reputation: TurboDSMer is more helpful than not
If you physical have both trubos then why don't you try it out. I don't see why you couldn't do it, not sure about any downsides but you can deffinatly do it.
Offline
Old 03-23-2005, 12:10 AM   #3 (permalink)
Proven Member
Reputation: Colossus is pretty helpful and trustworthy
Wouldn't it need to be rebalanced?
Offline
Old 03-23-2005, 05:06 AM   #4 (permalink)
Proven Member
hmm
i mean as far as the turbo workin half ways decent i do agree it would need to get balanced i am just curios because i have both turbos
Offline
Old 03-23-2005, 08:42 AM   #5 (permalink)
Proven Member
Reputation: 98TalonTSi is an unknown
Umm..I guess you could, but why would you want the fuss...Do it right the first time and it'll save you some headaches later.
____________________________
-Mike
Offline
Old 03-23-2005, 09:26 AM   #6 (permalink)
Proven Member
Classifieds Rating: (6)
Reputation: Omega is more helpful than not
You want to use the 14b CHRA with the 20G hot and cold side? Um, assuming the shaft was the same you *might* be able to... but for all intensive purposes... no.
Offline
Old 03-23-2005, 09:37 AM   #7 (permalink)
Proven Member
reply
no i would just be using the cold side 20 g compressor wheel and putting it on the
14 centersection using the 14b exh wheel, so basically a stock 14b with a 20 g cold side
compressor wheel of cousre i would use the 20 g comprsssor housing
Offline
Old 03-23-2005, 10:15 AM   #8 (permalink)
Proven Member
Classifieds Rating: (2)
Reputation: DSMraver is more helpful than not
Yes, needs to be rebalanced. For a better working 14b, you *CAN* swap the exhaust housings, they are designed for the same turbine wheel.
- John
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.14780688 seconds (62.75% PHP - 37.25% MySQL) with 9 queries
