ChameleonLizard
- Dec 28, 2003
Milton,
Florida
I was curious if I could put a manual transmission ecu in my automatic 91 gst. I already have the cams and injectors out of a 5-speed laying around. I was going to slap a 14b in as well to get away from my tiny 13b. But i was wondering if it would screw up my car getting the ecu from the 5-speed as well. Basically something that would answer my question is knowing whether or not the ecu and tcu work together.
do u see any wires coming out of the regulator. how ever yes the auto regualtor runs at 42 and mt runs at 37, so the ecu does run the 4 injectors differently causs it will assume that your base fp is at 37 with the mt ecu, so in return your car will run a little bit richer causs you will still have the higher 42 psi regualator on the rail, unless you swap that out also. which if u have access to that should work out
