my_gst95
- 569
- 10
- Nov 13, 2002
Sacramento,
California
I logged my car one night and notcied that it started knocking (aprx 10 counts) at only 14 psi. Not thinking much of it, I later put 100 octane and was tuning with no sign of problems (0 counts, perfect timing at 19psi of boost). Later, I put 91 octane back in for daily use and now it seems even worse (17 counts of knock). I had to put my safc close to +18 just to keep my timing where it needs to be. And I know it has to do something with my fuel delivery system because my O2 #'s are lower then ever before (usually they are .89-.87, now they are .83). Is there any way to test out my injectors or pump to see which it would be? I even tried changing out my fuel filter to a standard new Fram, and it didn't help at all.
90GSX
255lph (not rewired yet)
stock 450cc
s-afc
tuned with MMCD software
Will the IPW tell me anything (ie if the injectors aren't spitting enough fuel?).
my_gst95
90GSX
stock 450cc
s-afc
my_gst95
