AWDTURBO02
- Mar 8, 2003
When I am full throtle what am i suppose to be at on the gauge? Am I suppose to be 2,3,4 bars in the green? Can anyone answer this for me?
Thank You
Greg
Thank You
Greg
Originally posted by AWDTURBO02
OK moron, if it was in the red area you would be running lean, which you should be when you idle, not at full throttle. Is your a/f gauge in the red when you are at full throttle, cause you car is gonna blow something if it is. You first off should be some where in the green or yellow area.....Think about it...
