indy1979
- Mar 31, 2002
Conyers,
Georgia
Can the ECU adjust 550cc injectors well enough to not need a fuel management controller? I do have the HKS S-AFR if needed, but I think the ecu can control the 550's. The engine is FULLY built, rods, pistons, knife-edged crank, blueprinted and balanced rotating assembly, lightened stock flywheel, HKS 272/264 cams, SS 1mm oversized valves, crower springs and retainers, etc. FULLY built.
Sam
Sam
