boostineklipz
- 1,361
- Jun 2, 2002
1,
Maine
Alright, after a couple days of trying to fine tune the big 16g, I decided to take a look at the spark plugs. They were a greyish white, but more white then grey. So it appears I am running lean. What I dont understand is what the pocketlogger is showing me in 3rd gear:
3864 RPMS
11 degrees- timing
o2-.94v
4574 RPMS
7 degrees- timing
02-.96v
4928 RPMS
19 degrees- timing
o2- .96v
5460 RPMS
13 degrees- timing
O2- .98v
5860 RPMS
22 degrees of timing
02- .98v
I know 15-16 degrees of timing is optimal for a 2g. What the hell is going on here, am I running rich or lean. The pocketlogger leads me to believe I am running rich but the spark plugs show something different. The S-AFC is set to around -17-18 for high settings with 550s and a walbro 190.
3864 RPMS
11 degrees- timing
o2-.94v
4574 RPMS
7 degrees- timing
02-.96v
4928 RPMS
19 degrees- timing
o2- .96v
5460 RPMS
13 degrees- timing
O2- .98v
5860 RPMS
02- .98v
