gsxstac
- 252
- Sep 27, 2002
bellport,
New York
DO I HACK OUT THE HONEY COMBS IN THE GM 3" MASS OR LEAVE IT THE WAY IT IS???
Unless you are running some very big stuff leave it in. It flows 2 to 3 times more stan stock the way it is.Originally posted by gsxstac
I am running a 60-1 & still have not seen the need to gut the mas yet. You keep divability with the mass uncut.These mafs flow around a 1000cfm.I believe I would leave it along for now anyway & see how it works when you get your 60.But I also have seen the hipo aftermarket gm maf has no honeycomb so maybe its worthy of doing,if you have a extra it would be worth trying.If you gut it let me know how it works. Thank You & good luck.Originally posted by gsxstac
well i'm runnin a 20g right now and will be upgrading to a 60 trim shortly.
Originally posted by swordfish
That maf will flow up to 1250 cfm. Your gonna have to upgrade to one helluva turbo before you need to start hacking.
jeff [/QUOT I dont think its worh hacking these mafs, but just wandering what does the 3 1/2 maf flow it is what I am running.
