For 1g guys using te 2g MAS...does this make sense?
Ryan H
70
Nov 19, 2002
Okay, so here it is. The 2g MAS runs 20% leaner than the 1g mas right so it would make sense for us 1g guys that are running the 2g mas to see 20% less on the Hz readings when compared to the 1g mas?
In my case my max Hz with the 1g mas was 1800, then when I swapped in the 2g mas it went down to 1500Hz, that is about 20% less...makes sense right.
So the final question is in my case now with the 2g mas I'm hitting max 1800Hz, so would it be right to say that in fact I am actually flowing 2150Hz if I was to have a 1g mas? cause i keep seeing a few of you guys with the same setup as me but running a hacked 1g mas or Al bhala whatever mas pushing 2100-2200Hz, yet i can only manage 1800 with my 2g mas.
Any input would be great.
i think your right, i remember seeing like 1900-2000hz on my 14b 1g mas at like 15psi, now on my 20g with 2g mas at like 18psi i hit like 2000 or a little over
i usually dont watch the hz, i think its right around 2000 or 1900 with the 2g mas
Well it does make sense...hope i'm right cause all I can manage with my 18g at 20psi is 1800Hz.
yeah i barely hit 2000 at 20psi on my 20g, i didnt look at it when i was running 24-25psi, i usually dont watch the afc hz's
Htz dont mean much....but I own you, I got 2400/pumpgas and on my 20G. Cams give you about 250 more so I had that helpin me =)
When considering 1g MAF's, Hz will vary widely depending on the amount of hacking done.
