BoostAddict
- 37
- Dec 2, 2002
I need some help with my S-AFC, please do not critize, as I've tried to find the answer but can't. I've got a 16g, 650cc injectors, 255lph fuel pump, B&M fuel pressure regulator, big greddy front mount, and all the supporting mods. I know I should have it tuned on a dyno or by a pocketlogger, but I don't have the money to do that yet, and need help on tuning it now. I'm trying to run right around 20psi of boost. I've found out that if I go any richer then -40% the car seems to like stutter, and not want to move really on hi throttle. My hi-throttle point is at 80%, and low is at 30%. It seems the leaner I go the better it runs, and the quuicker it is. As of right now its set all the way down to -50% leaner. The EGTs are right around 14 F, which I was told is safe. The car is pretty quick, but seems like it could be quicker. I have a boost leak tester comming in soon, as I was also told at one time that a boost leak could make you run leaner, if this is true I don't know. I just need to know if these settings are right. Also, on low throttle, the car only seems to run smoothly and good at -25%, which seems pretty lean also, but the a/f cycles from lean to rich, which I was also told is what its supposed to do. Any help would be nice. I don't really know much about fuel tuning yet, so please don't critize me for any wrong doing.
