Grizzly Racing
- 151
- 2
- Jul 27, 2002
PA,
Pennsylvania
i readjusted my base timing from 10 degrees back to 5 degrees. before this the car would idle perfect at 1000 rpm. i try to keep it around 1000 because of the webcams.
now the car idles at 500 rpms and no matter how i adjust the screw in the throttle body i can not get the RPMs to change at all.
stock ecu/injectors, no fuel computers, mas only has removed normal honeycombs, no hacking.
thanks for any help.
