DSMeanie
- Mar 13, 2003
Toronto,
I just finished installing my Paxton fuel pressure regulator and I'm having difficulties getting the right reading on the gauge.
I am trying to attain 42 psi but the needle is vibrating violently that it reads between 30-50 psi. This is with or without the vac hose attached.
How do you set the correct psi with a gauge that behaves irratically? BTW, it's a B&M gauge.
When I shut off the car the gauge shows 40 psi.
