Grizzly Racing
- 151
- 2
- Jul 27, 2002
PA,
Pennsylvania
i pocketlogged my 91 GSX. shows i'm lean across the RPM band. also getting a lot of knock (20 count) and its retarding my timing. all the way from 4k-redline.
i have stock ECU, ported 14B, 95 pistons, ported head, 7-angle valve job, ported 95 manifold, full exhaust 2.5", webcams, walbro 255hp pump with rewire, 2.5" upper IC pipe, 2.5" TB elbow, colder plugs.
i have my MAS screw backed all the way out and usual honeycomb removed.
i am only running 15psi of boost but want to run 20psi.
i do not want to back my MAS screw back in.
i read about Installing a 10k pot near the ecu i think wire PIN #8 which is the air temp sensor and basically it tells ecu air is colder then what it is and then adds more fuel. i have this link.
i also read somewhere about putting a POT into the MAS and richening it up that way. what sensor does this affect?
does anybody have links to the MOD that involves the MAS?
are these 2 mods the same mod? just using different locations to install the pot? or is it 2 different sensors that you are adding resistance too?
which of these MODS is the better choice?
is anybody currently using any of these mods?
thanks for any help
thanks for any help
