Zerocygnal
- 639
- 1
- Jul 1, 2002
Springfield,
Ohio
My fuel trims are 140% for Low, Mid and High....my old and new O2 sensors do the same thing...? The ECU has been replaced and for the most part everything runs fine. A slightly rough idle is the only real problem I've had.
At idle the O2 will not cycle all the time, you have to tap the pedal to get it to start cycling.
At WOT it will sit at .90 and climb it's way down all the way to .25 but the knock is only reading 10 to 17 counts.(Bad enough). Any other ideas as to what is causing this? Bad ground...?
Stats:
94 Octane Sunoco
22psi on 14b
Typically had a .92 to .93 O2 @WOT with 0-8 counts of knock before
Here is the log...
This is a 3rd Gear pull
Stats:
94 Octane Sunoco
22psi on 14b
Here is the log...
