97 leaning out?
doodlem
Mar 29, 2003
coon rapids, Minnesota
Could someone tell me if i am leaning out or what the deal is, i know at WOT you A/F gauge isn't right but when i get on it at the top of 2nd and 3rd the guage goes for rich then works it way to lean. I plan on getting a WBO2 soon but i would like to understand how to read these numbers off the pocketlogger. Possible O2 sensor going bad?
@ WOT Fuel trim and 02 trim do not change
STFT 0 LTFT 5 O2 T1/T2= 0
RPM___ Timing TPS____ O2 bank 1 O2 Bank2
796____ 14___ 9.82____ 0.56___ 0.12
2280___ 30___ 17.29___ 0.54___ 0.16
2484___ 29___ 18.07___ 0.22___ 0.72
2808___ 19___ 97.05___ 0.96___ 1
4952___ 15___ 97.45___ 0.94___ 0.98
5368___ 11___ 97.45___ 0.92___ 1
4928___ 13___ 97.45___ 0.26___ 1
5852___ 20___ 97.45___ 0.1____ 1
5168___ 11___ 97.45___ 0.1____ 1
4804___ 13___ 97.45___ 0.06___ 1
5228___ 15___ 97.45___ 0.06___ 1
5636___ 17___ 97.45___ 0.04___ 1
5988___ 20___ 97.45___ 0.04___ 1
4704___ 11___ 97.45___ 0.06___ 1
4824___ 11___ 97.45___ 0.04___ 1
4960___ 13___ 97.45___ 0.04___ 1
5140___ 14___ 97.05___ 0.06___ 1
4768___ 32___ 0.79____ 0______ 0.94
3516___ 23___ 0.79____ 0______ 0.92
3072___ 23___ 9.04____ 0______ 0
I know TPS isn't exactly 100 but that is floored.
thanks for any help :confused:
Tune by timing. O2 value is completely worthless on a 2g. My O2 value starts at .84 and works it's way up to .86 by 7500rpms... :) Timing is excellent and the car still has that fuel smoke, so I know it's not too lean. If I lean it out anymore, then timing goes away... FWIW, YMMV
Log a 3rd gear pull from about 3k to redline and post that log, it will be lots easier to tell.
That log makes no sense to me, unless it is just a bunch of snippets from different logs. The rpm goes up and down, and you're at WOT the whole time.
....Kyle T.
First gear
Second gear
Third gear
I am going to get more runs in over the weekend, i will do what boostin said and do some 3rd gear pulls. AS for the RPMs i dont know what the deal is this is the data the my pocket logger gave me i hope with the new runs this will make more sense.
Thanks for you help so far..
  • For sale 2g sunroof shade cover
    I have 5 sets of these. They are freshly re upholstered. The material I used was black suede. I...
    • Jose gonzalez
  • Wanted 2g ISO Rear Pass EDM Tail light
    Looking for only a passenger rear EDM tail light for my 2g. Please lmk if you have one lying...
    • Gabriel Pena
  • Wanted 4G63 ISO built short block
    Looking for either a 7 bolt split thrust or 6 bolt
    • Gabriel Pena
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale 2g 1996 Eagle Talon TSI AWD
    I have a 96 Eagle Talon AWD standard tranny for sale. The car still ran when I parked it. I had...
    • eli1977
