focusedrage
- 1,053
- Aug 3, 2002
Laytonsville,
Maryland
Considering getting a greddy model, there are cheeper ones that go in the engine compartment, which will better serve me?
Thanks
Thanks
Originally posted by tanner261
Hasn't anyone ever heard of a fuel pressure gauge isolator?
Yes, you can run a mechanical fuel pressure gauge in the cab.
Electrical FP gauge is more safer, accurate & faster response than mechanical gauge. Just my opinion.
You can't run a mechanical gauge into your cockpit
Originally posted by candela
You guys are wussies... I say run an mechanical oil pressure and fuel pressure in the cabin![]()
Originally posted by nowayout
it's good to use for testing to make sure your fuel pressure goes up with boost.
Originally posted by jdmawd
Originally posted by Turboniam
The reason I ask is because I am trying to determine off of which source to set base FP.
Pre-fuel rail or post fuel rail??
Meaning, obviously there is going to be a difference in fuel pressure that the in cabin gauge vs the one on the FPR will read... so which one do you set the base FP to??
Thanks for the help![]()
My question is refering to the two different locations of FP gauges.
I have one electronic in cabin, and the sender is located at the fuel filter, and another guage at the FPR.
Which one should I set the FP to? The in cabin aka pre-fuel rail gauge, or the FPR gauge aka post fuel rail??
