Boosted98gsx
- 2,099
- 22
- Oct 31, 2002
Houston,
Texas
Ok so i installed my new greddy egt gauge and got everything wired up right (so i believe) but my car reads 600*C at idle and at cruise it goes to 1200 and tops out easily. This is not under WOT or anywhere close to it. my trims are set so that they would be a little rich (11.0 a/f across the board) but that shouldn't matter because it should be in open loop. I dont understand why it is doing this. The probe is tapped into the uprising on the manifold in runner #4 next to where the hole for the bolt to hold the heat sheild down is. Anyone know any possible reasons/solutions?
