how to pass e/check without cat...but with MAFT...
Tallen
2,739
8
May 28, 2002
Ashburn, Virginia
think its possible? my stock downpipe is 1045 miles away in FL. with the old alcohol in the tank trick and tuning my translator to extra lean, think i'll pass? I bet Mike has some ideas on how to set it up to pass emissions :)
Is e/check emissions check? If so, then no I don't think it's possible.
First, at the very least, during the inspection they do a visual inspection to make sure you have a cat (aka get on their knees and look at the exhaust piping). If you have a straight pipe, you will fail this.
Second, if you have to do any kind of sniffer or testing of the exhaust gases, then I think you'll also fail; and leaning out the car with the translator should not help in my opinion...why... Because at low throttle, the ecu is still in control of the fuel. After combustion, it checks the o2 sensor voltage to see how close to ideal air/fuel radio it got. If it's off a little, it corrects this with fuel trims. When you decide to lean it out to pass emissions, the ecu will see that it's not hitting ideal air/fuel radios via the o2 sensor, and it will raise fuel trims to add more fuel to get it back to the normal level.
My advice, some how get a cat back on there to pass inspection.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
