bodymandave
- 36
- 1
- May 6, 2003
Hi- this is what i got
91 awd eclipse
16g
balance shafts removed,web cams, je pistons (9.5-1),550cc injectors,2g maf,
all the piping is aftermarket.bigger fuel pump,
question is-
the car's timing was off 2 teeth(belt).i had that replaced and now i need to redo the maps on the afc. i dont even know where to start.i just bought this car,so its all new,im a converted v-8 guy..
what way is rich/lean? low is +12,then+10 across the board, at 35% throttle. 80% is like +10 across the board..does this sound right?it idles rich,so with oversized injectors, shouldnt it be like 0 or -5 at 1k on the afc?i have technomotive datalogger program,and at wot its pulling no knock, .92 onthe o2's. and 850c egt..does this sound close? i do show knock when i let off the throttle though. can someone tell me the basics of using the afc?instructions on the website didnt help much. what way is rich/lean? etc... thanks in advance
Dave
91 awd eclipse
16g
question is-
Dave
