No more free datalogging software?
STARION
193
May 30, 2002
Nova,
the site that used to have the free datalogging software ( http://206.124.12.138/freeware.html ) doesn't seem to be working. Does anybody have any info? or know of another site that has freeware for datalogging? I just baught my cable and was about to d/l the software and go logging, but this has stopped me.
http://mmcd.meditprofi.ru/ isn't bad. At least it didn't need much work to get it to build on my systems. I'm still cleaning up the Palm'n'Stein code trying to get a clean compile but I'm not a genius anymore.
Binarys are provided for those not into hacking.
The MMC Datalogger doesn't seem to include the base timing in it's numbers (make sense because other MMC cars might not use the same setting), the conversion slopes on the temp values are off but PnS doesn't report any temps. The Fuel Trims look much more like what TMO reports vs PnS just reporting the 0 - 256, MMCd timestamps the log records and names the log for you.
Switching screens is tough when driving and one of the changes I have to add. You have to use the stylus on a little box to switch what things your looking at. PnS's digital display shows everything your logging at once but often crashes.
Try it and see how you like it.
Steve
