FlaToUt-GST
- 116
- 1
- Jun 14, 2002
I have just started using my pocket logger, and now all of the sudden the log info doesnt match up with the graph when viewing. While running the stylus across the graph the information wont start until right around the end of the graph and continue on. I tried using the slider thingy in the bottom right hand corner but that only helps a very small amount. Anyone else have this problem?? Also, what kind of timing should i be looking for at WOT on a 2g with only a 190lph pump (16g) 15psi? Thanks!
