halestorm
- Jun 9, 2008
Warsaw,
Indiana
I have a 1996 tsi 6 bolt swapped. it has crazy loud audible intermittent knock, which i am CERTAIN is ignition related. i have set double, triple, and quadruple checked ignition timing, tried 3 different cam angle sensors, 2 different ecus, and 3 different coil packs. the air/fuel is constantly pegged out at rich, and it may budge a few millimeters the other way occasionally. i know this is not a rod knock, the engine is freshly built, because i put bc 272s and a 1g cas in when i had a 7 bolt right before the swap and it was doing the same exact thing once i put the 1g cas on. i have link, and the computer recognizes when i plug it in but will not connect. i am at about wits end with this goddamn thing, if ANYONE has some insight or similar experience, or lives in northeast indiana who is willing to lend a hand it would be greatly appreciated.
