Which Injectors?
nolv4v8
104
Oct 21, 2002
Milwaukee, Wisconsin
I am debating which size injectors to get, 660 or 720? Originally I was going to get 660s, but that was when I was going 50 trim and now I ended up with a GT13 60 trim BB. Mike Huml said the 660s should be ok, but I am wondering if anyone thinks the 720s will be necessary. I am using an AFC/Logger combo, but will be purchasing the LS1 Maf translator so it shouldnt be a problem to tune the 720s. The gas around here is 93 octance also. Thanks. Also, where would you go to get the 720s? Any suggestions are appreciated.
Yeah that is what I figured, but alot say just stay with 660s. I plan on running between 20-22 lbs. on pump on the street and 25+ on race gas.
I would say with the amount of boost you will be running and the size turbo 720's would be your best bet.
:rolleyes: My buddy AT F2UNING was running 660 and ended up breaking his motor ...after lookin back he needed 720s at 24 psi
