if I add fuel at 3000rpm / 60mph...
Ricardo
312
Aug 23, 2002
Porto Alegre, South America
...is it supposed to lower my EGT temperature from 1400 F ? Coz I just tried that (+50%) on the highway and it didn't make a difference. I was not boosting or anything, not complaining about the temperature either, just wondering... coz I don't think the 450's can be maxed out at 20-30% throttle at 60mph :p
Were you maintaining speed/throttle (just cruising) or hard accelerating?
My guess is that you were just cruising meaning the ECU was running closed looped (ECU constantly adjusting fuel off of o2 sensor voltage). Try running wot with that AFC setting - if you even can ;)
Brian
Brian
Yeah, i was just cruising... im going to try that when i put 1000 on my motor.... it still needs to break in
