fmu raise fuel pressure?
an fmu is meant for n/a cars. it raises the pressure a set amount per lb of boost. For example a vortech 8:1 will raise the fuel pressure 8lbs for every pound of boost. I've seen people use it in place of an safc, but I'd just sell it.....
My friend who has a turbocharged Z24 used an FMU for a while. it worked fine. As the boost went up the Fuel pressure also went up. It worked fine for a while but then he upgraded to a full standalone. But it did work fine with his T3/T4 turbo, and it did a pretty good job at keeping it from runing lean as the boost went up.
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
