VPC Settings ,AFC Settings
alex1090
66
Jan 12, 2003
Downingtown, Pennsylvania
I am almost ready to start my fresh engine. I bought a VPC and an AFC. I would like to know what all you guys reccomend for settings. my fuel system consists of 660cc injectors,sx fpr,Walbro 255lph.
i need to know the settings that will get it to start then i will do the fine tuning later.
INTERNALS MODS
Stock Block and Crank
JE Forged Pistons
Carillo Rods
ARP Hardware
CYLINDER HEAD MODS
HKS 272/272 Cams
HKS Valve Springs
1mm Oversized Valves
Ported and Polished
5 Angle Valve Job
EXTERNAL MODS
Buschur Br-57 T3/T4 Turbo
Tial Blow Off Valve
Tial 35mm Wastegate
Turbonetics Exhaust Manifold
Buschur Sheetmetal Intake
75mm BBK Throttle Body
Full Buschur 3” Exhaust from Turbo back
Greddy 660cc injectors
BR/SX Fuel Pressure Reg.
Walbro 255lph Fuel Pump
ACT 2600 w/ Street Disc
Buschur Intake
Spearco Front Mount Intercooler
HKS Cam gears
Auto Meter Gauges
HKS VPC
APEX S-AFC
Greddy Turbo Timer
and i dont know how it happened but my car is a 91 not a 95
Its very hard to believe that you have all that stuff on the car and have zero idea how to go about base tuning. Where did you buy your vpc from how long ago and how much was it?
as far as tuning here is a shot in the dark for your starting point's
response 6 o clock
gain 12 o clock
idle 7 o clock
base fuel pressure 38 PSI
-25 across the board HI and LO table
start at 15 psi and makes a few logging runs. make fuel adjustments based on knock and timing. slowly increase boost knock should be under 5 counts timing should be atleast 16-17*
i had the car with 3 in exhaust and an intake then i broke a rod. i took the motor out with intentions of putting it back together stock and i guess i got a little carried away. I paid $550 for the vpc, from my buddy eric.
    • eclipsemf
