mattinthebox
- Jan 31, 2005
Detroit,
Michigan
I have a 1990 laser 2.0l non-turbo automatic. No mods, just a daily driven street car.
The original ECU - MD128624 (E2T34472) failed.
I put another ECU - MD166255 (E2T36572) in it and it ran.
I think it's from an 93 2.0l non-turbo.
After the swap I noticed it took a few cranks more to get it started and it also started like it was starving for fuel or something.
It seems to idle okay and drives alright but the tach will peg "0" RPMs if you floor the accelerator. Then when you let off, the tach will bounce back to where it's supposed to be.
It will also pop out the exhaust if you drive it hard and downshift manually.
A few Questions:
1. Is this safe to leave like this or will I damage other components?
2. Can anyone tell me the specs and component pin outs of these two ECU"s?
3. Is there anything I can do to correct the symptoms I get from the swapped ECU?
4. I can't afford a new or rebuilt ECU so any advice on repairing my old ECU? I have already swapped out the caps. The problem with this ECU is that my injectors don't seem to be firing. Fuel pressure and spark are good.
5. Has anyone else experienced this?
Many Thanks in advance!!!
A few Questions:
