Is this the right fuel pump?
He's a very cool guy...That's where i'm getting my 190lph pump from.He lives 2.5 hr away from me.With a 16G the 190 is more than enough.If you plan on going bigger in the furture then get the 255.
Are you aware about the base fuel pressure being raised on 2nd gen with the 255?
What do you mean by this? And I might get a 20g down the road but it wount be for a good amount of time. Will the 190 or 255 need to be rewired or will it be fine to just use the stock wires?
Thanks for any info.
you should rewire the pump to keep the voltage constant regardless of which pump you go with.
what he is saying about your fuel pressure is going to go up, he means that when you increase the size of your fuel pump it will inherantly increase your fuel pressure and overrun the stock fuel pressure regulator, that is why its suggested that you get an adjustable fuel pressure regulator for any fuel pump larger then the 190.
