datalog
kandt
151
Mar 27, 2002
could someonTime RPM Knock Timing O2 Airflow Air Temp TPS Coolant Battery ISC Accel Enrichment O2 Trim
0:00.24 2469 0 36 0.12 151 56 20 200 14.3 85 0 164
0:00.49 2469 0 36 0.86 151 56 20 200 14.3 86 0 152
0:00.74 2469 0 36 0.18 158 56 21 200 14.3 86 0 166
0:00.98 2500 0 36 0.14 164 56 25 200 14.3 95 6 162
0:01.24 2562 0 31 0.92 265 56 50 200 14.3 116 0 159
0:01.50 2594 0 30 0.1 296 55 59 200 14.3 120 0 100
0:01.77 2688 0 31 0.08 328 55 70 200 14.22 120 0 100
0:02.04 2781 0 31 0.1 365 55 72 200 14.3 120 0 100
0:02.31 2875 0 31 0.27 416 55 73 200 14.3 120 0 100
0:02.58 3031 0 29 0.78 466 55 73 200 14.22 120 0 100
0:02.86 3188 0 27 0.06 554 55 73 200 14.22 120 0 100
0:03.14 3375 0 26 0.06 680 54 73 200 14.22 120 0 100
0:03.43 3562 0 24 0.06 882 53 71 200 14.15 120 0 100
0:03.70 3875 0 21 0.71 1021 52 67 200 14.15 120 0 100
0:03.96 4125 2 20 0.9 1115 52 64 200 14.15 120 0 100
0:04.19 4406 1 21 0.9 1197 52 64 200 14.15 120 0 100
0:04.41 4656 1 21 0.92 1279 51 64 200 14.15 120 0 100
0:04.65 4906 1 21 0.92 1367 51 64 200 14.15 120 0 100
0:04.84 5188 0 22 0.9 1443 51 63 200 14.08 120 0 100
0:05.02 5344 6 22 0.92 1499 50 63 200 14.08 120 0 100
0:05.19 5562 6 23 0.9 1518 50 62 200 14.08 120 0 100
0:05.37 5719 5 24 0.9 1525 50 59 200 14.08 120 0 100
0:05.55 5938 12 24 0.9 1506 50 58 200 14.08 119 0 100
0:05.74 6094 12 24 0.9 1487 50 57 200 14.08 119 0 100
0:05.92 6219 11 24 0.9 1493 49 55 200 14.08 117 0 100
0:06.11 6375 11 25 0.92 1247 49 25 200 14.3 109 0 100
0:06.36 6219 3 44 0.94 214 49 10 200 14.3 94 0 100
0:06.65 5844 0 45 0.84 164 50 33 200 14.3 91 6 100
0:06.94 4594 0 29 0.82 643 50 70 200 14.22 120 0 100
0:07.21 4375 2 26 0.8 895 50 71 200 14.15 120 0 100
0:07.41 4375 1 21 0.84 1159 50 67 200 14.15 120 0 100
0:07.66 4469 1 21 0.88 1197 50 62 200 14.15 120 0 100
0:07.88 4625 1 21 0.88 1216 50 62 200 14.15 120 0 100
0:08.08 4656 0 21 0.88 1235 50 62 200 14.15 120 0 100
0:08.27 4781 0 21 0.88 1254 49 62 200 14.15 120 0 100
0:08.49 4844 7 19 0.88 1273 49 62 200 14.15 120 0 100
0:08.67 4906 6 20 0.88 1304 49 61 200 14.08 120 0 100
0:08.90 5031 6 20 0.88 1329 48 61 200 14.15 120 0 100
0:09.16 5094 6 21 0.9 1266 48 54 200 14.15 117 0 100
0:09.36 5219 6 23 0.88 1241 48 53 200 14.15 117 0 100
0:09.57 5250 6 24 0.88 1254 48 51 200 14.15 116 0 100
0:09.74 5344 6 25 0.88 1222 47 51 200 14.15 116 0 100
0:09.93 5406 5 24 0.88 1222 47 51 200 14.15 116 0 100
0:10.13 5469 16 22 0.88 1241 47 51 200 14.15 116 0 100
0:10.33 5500 16 22 0.88 1247 47 50 200 14.15 115 0 100
0:10.52 5562 15 23 0.88 1254 47 50 200 14.15 115 0 100
0:10.69 5656 15 23 0.88 1247 47 51 200 14.15 117 0 100
0:10.89 5812 20 21 0.88 1386 47 56 200 14.15 119 0 100
0:11.06 5781 19 22 0.88 1405 47 56 200 14.15 118 0 100
0:11.25 5906 24 20 0.88 1411 46 56 200 14.08 118 0 100
0:11.43 5938 24 21 0.88 1405 46 54 200 14.08 116 0 100
0:11.62 6000 23 22 0.9 876 46 10 200 14.3 106 0 100
0:11.92 6062 11 42 0.94 208 47 10 200 14.3 90 0 100
0:12.18 5469 0 45 0.92 189 48 31 200 14.3 96 3 100
0:12.44 4469 0 32 0.31 567 48 59 200 14.22 120 0 100
0:12.75 4531 0 28 0.82 857 48 61 200 14.22 120 0 100
0:12.98 4562 19 16 0.84 1178 48 60 200 14.15 120 0 100
0:13.20 4594 19 14 0.86 1210 48 60 200 14.15 120 0 100
0:13.39 4594 19 15 0.86 1222 47 60 200 14.15 120 0 100
0:13.62 4719 18 16 0.86 1235 47 60 200 14.15 120 0 100
0:13.87 4812 18 16 0.86 1235 47 59 200 14.15 120 0 100
0:14.11 4844 18 17 0.86 1229 46 58 200 14.15 120 0 100
0:14.33 4906 17 17 0.86 1241 46 57 200 14.15 119 0 100
0:14.50 4906 17 17 0.86 1229 46 56 200 14.15 118 0 100
0:14.69 4906 17 18 0.86 1229 46 55 200 14.15 118 0 100
0:14.89 5031 16 18 0.86 1229 46 53 200 14.15 117 0 100
0:15.13 5031 16 19 0.88 1077 46 38 200 14.22 106 0 100
0:15.41 4938 11 42 0.16 246 46 10 200 14.3 89 0 100
0:15.70 4938 0 45 0.88 158 47 10 200 13.93 72 0 100
0:15.96 4438 0 43 0.9 120 48 10 200 14.3 56 0 100
0:16.21 4062 0 28 0.88 82 48 10 200 14.3 54 0 100
0:16.45 3531 0 27 0 69 49 10 200 14.37 54 0 100
0:16.70 3312 0 27 0 76 49 10 200 14.37 54 0 100
0:16.95 3875 0 28 0 69 50 10 202 14.3 54 0 100
0:17.20 3812 0 28 0 69 50 10 202 14.37 54 0 100
0:17.44 3719 0 27 0 69 50 10 202 14.37 54 0 100
0:17.69 3719 0 27 0 69 50 10 202 14.37 54 0 100
0:17.93 3656 0 27 0 69 51 10 202 14.37 54 0 100
0:18.18 3625 0 27 0 69 51 10 202 14.3 54 0 100
0:18.75 3531 0 27 0 69 52 10 202 14.37 54 0 100
0:19.00 3438 0 27 0 69 52 10 202 14.3 54 0 100
0:19.24 3406 0 27 0 69 52 10 202 14.3 54 0 100
0:19.49 3375 0 27 0 69 53 10 202 14.3 54 0 100
0:19.74 3312 0 27 0 69 53 10 202 14.3 54 0 100
0:19.97 3250 0 27 0 69 53 10 202 14.3 54 0 100
0:20.22 3250 0 26 0 69 53 10 202 14.3 54 0 100
0:20.46 3188 0 26 0 69 53 10 202 14.37 54 0 100
0:20.70 3156 0 26 0 69 53 10 202 14.37 54 0 100
0:20.94 3125 0 26 0 69 54 10 202 14.37 54 0 100
0:21.18 3094 0 26 0 69 54 10 202 14.3 54 0 100
0:21.42 3062 0 26 0 69 54 10 202 14.3 54 0 100
0:21.66 3000 0 26 0 69 54 10 202 14.3 54 0 100
0:21.90 2938 0 26 0 69 54 10 202 14.37 54 0 100
0:22.14 2906 0 26 0 69 54 10 202 14.3 54 0 100
0:22.38 2875 0 26 0 69 54 10 202 14.37 54 0 100
0:22.62 2844 0 26 0 69 54 10 202 14.37 54 0 100
0:22.87 2812 0 26 0 69 54 10 202 14.3 54 0 100
0:23.11 2781 0 26 0 63 54 10 200 14.37 54 0 100
e evaluate this log. this is on 15psi on 93 octane
You need to richen it up quite a bit at 4K up! It's too lean and you're knocking like crazy!
Really all you need in the log is RPM, Knock, Timing, and O2 :D
Since you don't have injectors or an afc yet with that big turbo I'd say either turn the boost down, or richen up the mas a little and log it again!
You could stand to have a little more fuel above 5500, but apart from that it looks pretty good. I suspect that if you'd held the high RPM/load for a bit longer, you'd have seen a bunch more knock coming in and your timing suffering accordingly.
It also looks like you weren't actually at full throttle; the TPS reading doesn't make it over 73.
You might want to try formatting a bit more carefully if you want better analysis...
correct me if Im wrong, it says your TPS was never anywhere near 100% meaning you never went to WOT.. to tune a car for power you need WOT logs, not partial throttle.. partial throttle is just for driveability.
  • For sale 1g 90 Oil Cooler
    • kyler021
