01-08-2003, 01:26 PM
#1 (permalink)
Proven Member
720's and idle?
Well it's time for my next upgrade, injectors. I plan on using something bigger than the L2R. After reading about Larryd maxing his 660's out which I was going to get (sizewise). I am thinking I need bigger. How bad is it to get 720's to idle with piggybacks? I have a VPC and a S-AFC for tuning (I know some sort of standalone would probably work better but that's not the answer I'm looking for). Thanks......
PS. I know there are like five posts under this one about injectors but none answered the idle question.
Offline
01-08-2003, 01:32 PM
#2 (permalink)
Proven Member
I have 720 and they idle fine. but I do have dsmlink thou. I think they should work as long as you fist replace the turbo and then install the 720.
____________________________
Mike
98 GSX
06 EVO IX MR
Offline
01-08-2003, 01:38 PM
#3 (permalink)
Proven Member
I am maxing out my stock ones now with the stock turbo ported. I will be getting a turbo like a month or two after the injectors. My freind has 720's as well, with DSMlink, his runs fine. I'm still in the dark ages with my piggybacks though!
Offline
01-08-2003, 01:43 PM
#4 (permalink)
DSMtuners Wiseman
Quote:
Ditto.
-Sean Caron
Offline
01-08-2003, 02:05 PM
#5 (permalink)
Proven Member
Hmmm, maybe I should just sell all my stuff and get the AEM. I ahven't done any research for AEM yet (I am happy with what I have now is why). Do you have to run a MAF with that?
Offline
01-08-2003, 02:24 PM
#6 (permalink)
DSMtuners Wiseman
Quote:
If you have to ask, you shouldn't get one.
-Sean Caron
Offline
01-08-2003, 02:27 PM
#7 (permalink)
Proven Member
Okay so when I didn't know anything about a DSM and was going to buy one I said "should I get a 1G or a 2G?". Does that mean I shouldn't even own one? I don't mean to sound rude but we would still be riding in carriges if someone somewhere hadn't asked a question. But oh well I guess I'll just stick to what I have since that's all I know.
Offline
01-08-2003, 02:31 PM
#8 (permalink)
Proven Member
PS after reading my above post about the AEM, that was a really stupid question. Like I said I haven't done any research at all on them because I don't need one. So you are right.....
Offline
01-08-2003, 02:33 PM
#9 (permalink)
DSMtuners Wiseman
My post wasn't meant to insult, it was meant to light a fire under your butt and make you research an AEM setup to see if you really need it. It seems to have worked.....eventually.
Besides, would you rather have me post "Search!".
-Sean Caron
Offline
01-08-2003, 02:40 PM
#10 (permalink)
Proven Member
Haha, search what's that?
I don't think I am anywhere close to needing the AEM. Unless I want to pop my hood so people can check out my "standalone fuel managment system"
I'll just stick with what I have and hope the injectors are okay.
Offline
01-11-2003, 12:05 AM
#11 (permalink)
Proven Member
to you guys running the 720s and the DSMlink, what brand 720s are they? I thought I had read something on the DSMlink group stating issues with the link and certain 720s?
Offline
01-15-2003, 12:41 PM
#12 (permalink)
Proven Member
I've been looking into the 720cc and it is getting easier to tune for me.. My biggest problem is with the CAS Reg witch I've been dealing with. Not too fun, and the fact that winter gas has oxygen in it that has been causing some problems. But I have fix any problem with the injectors tuning issue. They are denso and they work fine. I don't see any problem or issues any more.
Mike
98 GSX
06 EVO IX MR
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
